- Joined
- Jul 7, 2011
- Messages
- 17,463
- Reaction score
- 27,388
EnormadomeSmall room jam, no problem. Small bar, low ceilings, yer pushing it. Mic the sucker and run through PA to play Enormodome.
And Bingo was his name o.You're either going to have to mic it, or get a bigger amp IMO. For a heavy handed drummer playing rock, I've always needed about 30W minimum, but then again I do want to have cleans from time to time. Sometimes a 22W Deluxe Reverb sized amp works OK for me, but I generally need more headroom.
When cranked, you might find that it's loud enough but completely falls to mush and flubs out. YMMV and all of that, but I don't think that it's going to work for you.
You won’t regret it. Metal NEEDS a tight low end that you won’t get from a 5 watt amp without a PA reinforcement. You actually don’t want the power section breaking up too much, which happens VERY early on the dial for most 5 watt amps. After all, that’s why we typically buy them.Thanks for the replies guys
The price point seemed very promising so I was just speculating.
That's a $250 handwired head.
I'll look into their 20 watt version, but it's more than twice the price
You should load up a 4x10 extension cab for those occasions. Nice and light, nice and loud.Fender Champ worked for me when the drummer used electronic drums. Not so much with real drums. Took the Princeton which is 12 watts to sit in with some guys last year and the drummer drowned me out using that.
I definitely prefer 6v6 for single ended.But no master volume?
that may be a good option, I think in general I prefer push pull designs (meaning two power tubes) of a single ended design. Overall they tend to be less raspy and you will have a little more control of your sound via pedals ect...
A single ended el84 basically sounds like a hornet fart in my experience![]()
My friend had a katana for a while and loved it. It’s light as a feather, loud as balls and super versatile. He used pedals for his dirt, so I didn’t hear the actual amp’s dirt, but as it’s made by a pedal company I’m sure the dirt is fine.makes sense.
it is their flagship model.
Probably worth the price too.
Should be better than other amp heads at that price.
But I'll need more money for a cab
Its either gonna be this or a katana
For metal, I’d buy as much wattage as I could afford. Small room, 20w will do, with the right cab.
That being said, there’s lots of different kinds of metal. But a tight low end is pretty typical
I should probably change that. In my OP, I said there would be quality PA.I voted no on survey, ASSUMING it meant GIG with a 5 watt, unmic'ed
By the time its shipped to India its more like $450.Maybe consider this $250 one?
Monoprice 611815 15Watt, 1 x 12 Guitar Combo Tube Amplifier with Celestion Speaker & Spring Reverb
I'm not qualified to say anything about using it to gig, but the online reviews are good, and I think it sounds better than my Epi Valve jr 5W. Monoprice also makes heads.
Exactly what I intended.I agree with most others. If you run it through a PA there is no reason you couldn't gig with it. There are too many examples of players going direct and only using monitors to say otherwise, IMO. I like stage volume for vibe. But it isn't necessary for the audience.
I just wanted to be able to monitor my guitar via the cab.
