If guitar wood does not matter....
  • Thread starter Ginger Beer
Ginger Beer
I read several claims recently on this forum that guitar wood does not matter. That 99% of the sound is in the electronics. A concrete guitar sounds the same as a les paul and so on.
My question is...If wood does not matter, why can I take a pickup off of one guitar, put it in another and have it really sound substantially different? Be it shrill, muddy, more midrangey...why the drastic difference?
JTM45
Platinum Supporting Member
:io:
Lesson learned here. I'll just stick to laughing, it's better for the soul. :laugh2:
Tom.Ashworth
Because wood does matter :)
But while you may only be swapping the pickup the electronics inside the guitars may differ (pots, caps etc) and the metals used in hardware may vary. Construction also plays a large part in tone. A bolt on neck compared to a set neck will produce tonal differences. Preference of construction is arguable but it does change tone.
However wood must make a difference or in this modern world Gibsons would be made out of Balsa wood
Barcham
Elitist Club Member
It all depends on what name is on the headstock. :cool:
Ginger Beer
Does the tailpiece screw into the wood or is it really the other way around?
HRC
My Les Paul has a poly finish but it has worn through on the back, can the wood now breathe like a dolphin?
Yes but when you have to much to drink don't forget to let it come to the surface for air.
