And will you post pics or something? I'm really GASsing for a ssc 55 in burst.
I did post pics, but more importantly, clip.
They are nice guitars, Indonesian made.
The pickups do a nice approximation of both P90 and humbucker sound.
The neck has an inverse heel to allow higher access.
The bridge is also the tailpiece - sustain? Holy merde! Only two holes in the body.
The models with visible grain are solid ash while the opaque ones are mahogany...so much for tone wood.
The next model the 55, has a third position in the pickup mode selector switch to allow both P90 and humbucker, whereas the 33 is either or. The difference is utilizing an extra conductor in the pickup configuration - 3 wire versus 4. So it is not merely a question of changing switches.
The 77 model is hollow.
The body is curved, which I suspect adds to the poor center of gravity. But the idea was to allow for a guitar that was made to fit your belly rather than a belly cut in the guitar.
On the cheap side, the neck is "grafted" onto the body, i.e. no tenon type construction. The shielding paint in the cavities is that matte black garbage so prevalent with knocks offs.
The thing has SEVERE neck dive.
So much so that Vox came out with "Strap Button Extender" to place a strap button on the horn rather than on the back. It does help quite a lot, not a complete cure.
Curve of body
Inverse heel
New strap button and dyed fretboard
Abalone knobs
