i have no switch, just 1 volume pot and one tone pot. i have come to understand that the rating on the pots will only change it's tone, not keep it from working...unless defective, of course. they both respond to my meter from 0 to somewhere short of 490 on each, and operate smoothely. my cable is okay, as i plugged it into another guitar and is---and has been---working okay. I have wiggled and jiggled and found nothing works. for some reason, occasionally it will come on initially when plugged in, but then after a few seconds, it goes dead. when working the volume, i can hear it amplify in the amp, but when i tap on the pole pieces, i get nothing. somewhere down the line, it appears the feed to the pup is being interrupted. i even resoldered my ground on my jack, but didn't make a difference. i'm gonna start over with my new cts pots and see what happens, but i like to use this as a learning experience by locating my problem before i gut it and start over, because it may work just fine after redoing, and i won't really know what my problem is. (besides not knowing what i'm doing)
thanks.
