Wiring please help!
Galloway
Ok so I'm in the middle of installing a mojotone wiring kit into my standard faded, I've got most of it done but I'm a little confused because normally the jack wire runs into the body towards the switch but on this it went to the center plate along with the yellow, black, and the green... How should I wire this up? I've just connected the jack wire to the tone pot(which may not be correct) but should I just connect the others on the same pot or what?
[/URL][/IMG]
H.E.L.Shane
1) the CENTER conductor of the jack wire should go to the output of the switch.. the braided portion should be grounded (you have the braided portion grounded... but you also have the center grounded... )
Now... i BELIEVE the red wire should be the bridge volume to the switch
the white wire should be the neck volume to the switch
and the green wire should be the output from the switch (that gets connected to the center of the jack wire)
You'll have to verify the colors of the wires at the switch itself.. whatever wire is coming from the center of the switch is the output
