Hello friends,
it's my first post here
I'm a Les Paul and Marshall enthusiast from Portugal and am very happy that I found this great board now, sure will take a long time to get up to date as I'm just starting now!
I've checked the Wiring sticky thread on this forum but couldn't find the answer for my questions so would be very happy if you could help me clarify what are the wiring options for a standard Les Paul loaded with 2 conductor cables Seymour Duncan's with the normal Les Paul configuration (2 volumes + 2 tones + 3 way switch):
Considering that the 2 pickups are both 2 conductors cable only, what options do I have other than the 50s or modern wiring while maitaining the normal configuration options 2 tones, 2 volumes, 3 way switch (altough I can use push/pull pots but I don't want any drills for aditional switches on my precious Les Pauls
1) Can I wire it with a series / paralell option ?
2) Can I wire it with a push/pull DPDT tone or volume knob so that when I pull it the pickup signal bypasses all the pots and goes directly to the output jack?
3) What other creative options do I have for this configuration other than the 50s / modern wiring ?
I would be very gratefull if you could post some wiring schemes!
Many thanks in advance!
