Will Grover 102s direct fit
your idol
I have an 81 Standard, oddly enough its my first standard lf the era. Im not a giant fan of the tuners. Does anyone know if ant grovers would be direct drop in/bottom screw lines up? I eyeballed it with some milkbottles but they look like theyd come up short but i know on some models the screw hole is spacea a bit further.
thanks in advance for the help
Brek
They should be as long as they are 102’s, I bought some of ebay, and they were not, guy had three lots up, all listed as 102’s, two were, but when I clicked on buy, realised too late that the one I bought were not, the screw hole was to the side not centred.
Its not really the screw hole that is the key here at all.
Its the fact Grovers require a 10mm (3/8") headstock drilling. A lot of the vintage tuner designs have 8.8mm or 11/32" holes. Best to take 1 tuner off the back and see what hole size you have before realising you have to ream out once the tuners are already there.
Brek
Yeah, I kinda assumed the OP would have been aware of that, but maybe not, good catch.
your idol
They look like 10 mm on there. I have no doubt the shafts will fit i just dont want to put new screw holes in a 39 year old guitar if i can avoid it. I figure someone here must have made the swap.
Brek
Easy enough to find out take one off measure distance between centre to centre and compare with the specs published for Grover 102g’s. 10.5mm according to this:
Grovers typically 'kind-of' fit the lower hole on a Kluson type tuner.....but the screw typically sits fractionally off plumb as I think the hole is just enough out to be annoying.
