Width of Neck
  • Thread starter Ph03n1x
Ph03n1x
When people discuss slim necks they are referring to depth only right?
(ie. 60s vs. 50s necks).
Did Gibson make necks with slightly more narrow width (ie. E to E string) on any LPs?
dspelman
Width varied slightly over the years, but I think most are 1 11/16ths or 1 5/8ths. Other Gibson solid bodies have had narrower necks (the '70's L6S singlecut was around 1 9/16ths, for example).
But when most folks are talking about slim or thin necks, they're talking about depth. Otherwise you'll hear necks referred to as wide or narrow (usually referring to nut width rather than E to E).
I have a custom-built LP (non-Gibson, that is) that has a slightly wider (around 1 3/4" at the nut) neck *and* a thinner neck (17mm at the first fret, tapering to 20.5mm at the 12th).
