Which pot should the bridge ground wire connect to?
leonardygunawan.lg
In a standard les paul wiring.
The seymour duncan diagram tells me to connect them to bridge tone pot, but i assume it's okay to just connect it to any pot?
nuance97
Every Les Paul I can think of has the ground wire from the bridge going to the neck volume pot
Roxy13
Usually the wire is so short the neck volume pot is the only option, but if it's long enough I'll put it on the neck tone pot instead since the volume pots already have the switch and pickup grounds on them.
