larryguitar
- Joined
- Apr 25, 2009
- Messages
- 1,082
- Reaction score
- 2,769
Hi, as I'm working on learning more about winding I'm trying to find out what a 'full' bobbin actually is; in my mind, it's when the coil wire nearly overlaps the top and bottom of the bobbin itself.
Doing that, and with my current process, I can get about 5,500-6,000 turns of 42AWG single build poly on a 50MM bobbin (I'm using the ones from Philadelphia Luthier Supply) before it gets too dicey to proceed. I've read about folks winding 10K worth of 42 on a humbucker, and I'm wondering if those are special bobbins, or my process (hand-guided traverse) simply isn't efficient enough to put a 'full' load of wire on the bobbin.
I'd welcome the opinions of you experienced pickup builders--
Thanks,
Larry
Thanks,
Larry
