When do you STOP? (Conversion question)
jwinger
Jeggz, love the thread! The moment that you ask the question, "When do you STOP?" is quite possibly your subconscious trying to tell you something. It might even be now...
I'll be the heretic here. I don't think pots carry tone in a big way, because they are effectively resistive components, and unless their basic makeup had changed substantially since the 50s, changing them cannot make a huge difference. I change them for repros in any of my "player" guitars when required (generally hoping they actually read 550K+ when I get them), if just to lose the "vintage magic" of a scrunchy sound when adjusting volume, or occasionally the tone that I hear going up, when I have actually turned the control knob down.
A friend used to take repro pots apart and remove some grease to make them feel like the old ones, because they do feel a little stiff to turn. I might try it yet. Neither of us were terribly sold on "vintage taper", but I used RS "Super Pots" anyway, and the taper has suited me. It doesn't have an objective effect on tone to my ears.
I know vintage harnesses "complete" are a prized commodity, but the only electronic components that make an objective difference to my ageing ears are capacitors and pickup components.
Most of my 50's P90s still scream, so if the magnets are very degaussed by age, no-one told them yet. Capacitors maybe age less well, with most of my old ones reading well over where they were new, but they sound OK, and you just need to roll the tone off a little less. But they most definitely interact with the pickups in a characterful way that means good old ones, or great repros are worth having. Failing that, since I have gone full heretic this evening, I prefer a good Orange Drop to a knackered Bumblebee. There! I said it, and I feel better for it.
I noticed the other night that my "main squeeze" '59 replica has a mid 50's Bumblebee on the neck tone control, and a late 50's Bumblebee on the bridge tone control. The former is 0.018uF, and the latter 0.020uF, so I clearly sacrificed vintage correctness for what sounded better some time back. I think that was the result of experimentation back in 2011, vintage bees vs. Luxe. Luxe were really, really good.
I probably do need to change the pots in the aforementioned replica, but fortunately MOST of the 50s ones seem to be a little more resilient in my older Gibsons. I don't think I will lose any particular "magic" if I do need to change them though. I know how they work...
From your list, I would maybe shop for something that's not on it, which might be expensive, but late 50's PAFs can sound incredible. Failing that, I would just be playing that guitar. It has everything it could really need.
Liam
On the pots front Liam, if they are behaving weirdly, I've been able to sort it with the following on two.
They've functioned PERFECTLY the years since without a single crackle or inconsistency of taper. I'm constantly adjusting them also so they get more use than most. Prior to that I had inconsistent drop-outs and some signal coming through even with things ON zero.
Take the pots out being careful not to overheat. Carefully and gently ease the tabs up with a sharp headed flat screwdriver. The old metal can be brittle so go super slow and easy. Take the pot out the casing, and use a q-tip dipped in isopropyl alcohol. Gently rub on the exposed part of the track turning the shaft to change the part of the track that exposed till you've gone around the whole thing. Repeat until the q-tipn is clean and has no black residue. Similar to cleaning tape heads on a tape echo. Careful not to leave any fibres from the q-tip.
Carefully reassemble the pot and enjoy perfect functioning. If you are careful with the screw driver it's pretty much impossible to even see anything has been done.
Of course, would only recommend this if you've tried a spray of deoxit to no avail.
Worked a treat for me.
bosnialove
Johnny, have you put Vintage Long Magnets in to your Pat. No.'s?
I did with mine ('58 Longs) & I think that is a worthwhile upgrade & won't cost a bomb.
Cheers, Rudi
Where did you buy those magnets?
The Migty Zero
Ok so, my conversion has the purple wire Pat #’s, the milled saddle wired Abr, the formerly gold tailpiece, the 50’s long studs, the vintage Bees, the 50s Grovers, the 50’s thumbwheels.
All that’s left “tone” wise would be to find 50’s pots, 50’s tailpiece bushings and 50’s Abr posts.
But is it worth it?
The time?
The cost?
The effort?
She already has the 50’s TRC and knobs, but I wouldn’t drop any money in plastics.
What says you guys that been down this road?
Out of curiosity, in which order did you replace the parts and are they all vintage 50's parts? Which modification other than the pickups made the biggest difference in the sound, playability, and intonation from the stock pieces?
RAG7890
A well known / reputable Vintage dealer sold me the early '62 Patent No.'s & '58 Long Magnets.
The other sets I bought from a good friend who had a pretty solid collection of Vintage Guitars, Tubes, Speakers, Amps.........even a pretty famous Burst.
They are just sitting waiting to be used one day.
:cheers2:
Liam
Johnny,
Not even I clean tape echo heads anymore! But you know me well enough that you knew I'd get it... ;)
Feeling slightly lazy, I will get around to it.
Liam
jwinger
Johnny,
Liam
Lol. I loved my full-tone tube tape echo and it never let me down. Used to give it about 10 mins maintenance a month, so that wasn't the deal breaker for me...it was just the hassle of lugging it to gigs that I got tired of. Together the Kingsley serf and Dunlop echoplex pedal get my 95% of the way there with no extra hassle :)
Anyway...I digress...
jeggz
It had the pickups when I got it.
I added:
50s Tailpiece
50s Studs
Early 60s ABR
50s Thumbwheels
The biggest bang for the buck from the repro parts, was the ABR.
The Migty Zero
I added:
50s Tailpiece
50s Studs
Early 60s ABR
50s Thumbwheels
So was the bridge an early 60s ABR with aftermarket saddles? Which ones did you use?
bross63
You can get nickel plated brass abr bridge posts and correct sized thumbwheels (thinner and larger diameter than current production) from Philadelphia Luthiers. Brass is the correct material for the abr posts and thumbwheels, and I can affirm from my own experience that they do make a difference in the frequencies that resonate between the strings > saddles/bridge > posts/thumbwheels > guitar body and then back to the strings via the same resonant chain, when compared to steel posts and thumbwheels that are current stock even on the historic series reissues. The bridge itself is a bigger factor, but the posts and thumbwheels do make a difference. You want the “vintage thin” nickel plated brass thumbwheels. Here are links to the posts and thumbwheels...
The total cost for the posts and thumbwheels together is only $6.75, so it’s a no brainer if you want the correct hardware materials in your resonant (aka tone) chain.
jeggz
I have the Philly posts in her now , but the thumbwheels are 50s.
