What router bit for PU Legs & Wire Cavity?
dinkyguitar
Hi All,
What router bits do you guys use for the PU legs wire cavity and neck tenon?
Top bearing or bottom bearing? and what size?
dinky,
Ole'Lefty
legs= 3/8" and switch leads is 1/2" if you are using 1:1--I'm pretty certain of these-see if others have better info.
dinkyguitar
Thanks ole'lefty,
But what kind of routing bits would you need to prevent them from butting up against your template?
dinky
hardangerfjol
seems a basic question at first, but keep talking...
i am currently building a maple body and have weight to lose, so i simply routed the pockets all the way down.
regards, h.
Ole'Lefty
Mine have bearings-can be top, bottom or both. I'm pretty sure it is a Whiteside. For the 1/2 inch, the same if I am using a 1:1 template.
pshupe
I have a box jig which I use, so a top bearing or collar with the longest 3/8" bit you can find for pup legs and routes to be vintage correct. It is much easier to find a 2", or even 2 1/2" LOC bit for a 1/2" diameter bit. Use the 1/2" for all other routes like neck and control and switch cavities.
Try and get a plunge bit, which has 2 cutters that span halfway across the bit.
Cheers Peter
