What router bit for curved truss rod?
Twix
Im at the point of routing my truss rod curve and decided to do it how Roman Rist does it. This pic is Icegator's cutting bit and was wondering what do I all need to get. I looked at Amana 3/16 cuttting bit but do I get the 1/4 arbor,bearings, and cutting bit all seperate?
[ame=http://www.amazon.com/Amana-47600-ARBORS-NUTS-WASHERS/dp/B001NIC7CM/ref=sr_1_9?ie=UTF8&s=hi&qid=1257794314&sr=1-9]Amazon.com: Amana 47600 1/4 ARBORS, NUTS AND WASHERS: Home Improvement[/ame]
[ame=http://www.amazon.com/exec/obidos/tg/detail/-/B000P4OEO4/ref=ord_cart_shr?_encoding=UTF8&m=A1WO0LWTFI0BL8&v=glance]Amazon.com: Amana 53208 3 WING SLOTT CUTTER 3/16 KERF: Timberline Tools[/ame]
[ame=http://www.amazon.com/exec/obidos/tg/detail/-/B000P4LVEU/ref=ord_cart_shr?_encoding=UTF8&m=A1WO0LWTFI0BL8&v=glance]Amazon.com: Amana 47708 5/16 X .865 BALL BEARING GUIDE: Timberline Tools[/ame]
How many bearings do I get then? or do i get the complete setup?
[ame=http://www.amazon.com/exec/obidos/tg/detail/-/B000P4QC6M/ref=ord_cart_shr?_encoding=UTF8&m=A1WO0LWTFI0BL8&v=glance]Amazon.com: Amana 53408 3/16 KERF 3 WING ASSEMBLY: Timberline Tools[/ame]
monsterwalley
When I ordered mine I got the arbor and the cutter separate. Then I had a machine shop make a spacer for mine. Originally I was being a tight wad and used washers as spaces. Even though I thought I tightened the snot of the cutter, the washers ended up compressing a bit more and made my truss rod channel crooked. What I did was pretty dumb and dangerous as well. It wasn't balanced very well either. The spacer cost me 6 bucks at a machine shop.
