What guitar stand is good for Les Pauls?
decoy205
I've heard of some guitar stands that are not suitable for the Nitro finish. Apparently the nitro wears dude to the material it rests on. I've seen plenty of used pauls with those two brown spots on the binding from the stand.
Anyone know of a good quality stand that's sturdy and won't ruin the finish?
mmcquain
So far, so good with my Hercules hanging guitar stand (for on stage at church each week) and the wall-mounted String Swing hangers (for at home):
Case24
I agree, I have a Hercules stand and no marks from it. Very sturdy too. Rule of thumb, stay away from stands with that rubber that feels like surgical tubing.
decoy205
What about that black foamy type rubber? Does the hercules stand have that on the legs where the back of the guitar rests? How do you like the auto grab yoke for the neck?
Case24
The foam rubber is good and the guitar back rests on that arm you see sticking out in the picture above. I have a double stand that is the same concept (they also make a tripple stand). And I find the auto grab yoke works great.
johnreardon
If in doubt, do what I have done with my Rockstand. I believe, the foam rubber is afe, however, I have wrapped a sheet around the bottom and put socks on the prongs that hold the LPs
decoy205
cool thanks for the help. What do you guys think of this stand:
Product Picture
for some reason i like that there is something underneath the guitar supporting the weight not just by the neck.
LoKi
I have a rockstand that I use a lot. I don't like to leave the guitar leaning on its neck in any particular way for too long, so I rotate them every couple days... its a shame you can only play 1 at a time. :D
Otherwise I only use my A frame stand. The guitar sits, totally safe in a shaped bracket, and the back of the body rests on the top of the A on a foam pad. Nothing touches the neck at all. I've never felt good about hanging Les Pauls by the neck... they are so heavy... there has to be some unwanted forces pulling on the neck, headstock, or neck joint.
johnreardon
Product Picture
Personally, I don't like those type of stands, either for gigs or home use. They are probably fine, however, I think they are a bit unstable and prefer the old fashioned type similar to the one shown below
decoy205
Yeah I kinda feel the same way. LP's are very heavy and i feel like if its hanging by the neck something bad can happen. I'm just being very overprotective right now since I waited so long to get this guitar. I mean they do hang in the stores all day and night.
MIDNIGHT
smart! :applause:
lifele55
Been using the Hercules double stand for awhile now. The auto grab system is cool.
About hanging Lesters by the neck, I'm quite wary of it as well but since I only hang em when I'm taking breaks I won't bother too much. They'll usually end up back in the hardcase when not being played.
HolyGrail
John is 100% correct. Listen to him. Cotton is the safest protection
between any surface and Nitro .
You can wrap any foam or rubbers surfaces with old cotton socks.
mmcquain
...Otherwise I only use my A frame stand. The guitar sits, totally safe in a shaped bracket, and the back of the body rests on the top of the A on a foam pad. Nothing touches the neck at all. I've never felt good about hanging Les Pauls by the neck... they are so heavy... there has to be some unwanted forces pulling on the neck, headstock, or neck joint.
I'm not a fan of the A-frame stands since all the ones I've seen tend to lean the guitar back at a fairly slanted angle, which means you can't have it up close a wall, your amp, etc. I figure the more it is sitting out in the "middle" of things - the more chance of something bumping into it. This is why I prefer stands that keep the guitar in a more vertical position (e.g., the hanging Hercules stand).
As for hanging 'em... I used to worry as well but I've hung some of my Gibsons for several years now with no ill effects. All the guitar stores hang 'em by the neck and I've seen pictures of them hanging in the factory, etc. I think your run a bigger risk of neck problems from either extreme temperature/climate changes and (of course) anything that could allow the guitar to fall over (a sure fire way to snap a headstock).
johnreardon
I see where you are coming from. I just think the larger Hercules type stands get in the way on gigs and liable to be knocked. Even in a room, those stands seem to dominate things. Perhaps it's me being clumsy. I actually use the Rockstands. I sometimes take a 3 guitar rockstand with me on gigs.
A friend of mine has put some velcro on the side of his cab and leans his bass against the cab and ties the velcro around the neck. I thought it looked a bit wobbly, but it was rock solid.
TxMack
Hey...that's a cool idea!
lifele55
You know what I was picturing? A kid/dog running and swipping all those down and OUCH!
