Warm Audio EQ
Mustard Caps
Warm Audio EQ Hookup
How would you hook this up in your GUITAR pedal chain ???
IM also not worried about cost, size ect, and am only interested in how to do it.
Warm Audio EQP-WA
1-channel, 2-band Tube EQ with Transformer-balanced I/O, CineMag Transformers, Bandwidth Control, and EQ Bypass
drew365
Everyone will have a different opinion, but I put my EQ in the effects loop so I'm just doing a final tweak to the signal before it gets amplified.
KP11520
You'll need two TRS balanced to TS unbalanced 1/4 inch cables to plug it into the FX loop as described by Drew. TRS sides into the EQ, TS sides into the amp.
el84ster
I have a pair of these I use for recording/mixing/mastering...love them!
But for live guitar, keep in mind you have to feed this a line-level signal. So out of your guitar, boosted up to line by something, then into the eq, then out to whatever.
Also keep in mind that since your speaker only works up to about 5K, a lot of the high freq. adjustment on that unit will not be heard. Same for low below about 80 or so (again due to speaker liming freq. response).
