MaidenStrat02
- Joined
- Sep 21, 2008
- Messages
- 386
- Reaction score
- 29
Up for sale is this Voodoo Labs Pedal Power 2 Plus power supply. Comes with power cord, mounting hardware, and cables. Great condition. $125 + $10.00 for S&H in the U.S due to the weight.
Description:
The Voodoo Lab Pedal Power 2 Plus is a universal power supply for all battery-operated guitar pedal effects.
Pedal Power 2 Plus features include two outputs that will power Line 6 modeling pedals and two outputs that can have a variable voltage sag to emulate dying carbon batteries. Like the original Pedal Power, each of its eight outputs are completely isolated, short circuit protected, regulated and highly filtered. The Pedal Power 2 Plus comes complete with cables, detachable AC power cord, is handmade in the USA and carries a 5-year warranty.
Boss Pedals-There are two types of Boss pedal effects, which specify either PSA or ACA type power supplies. Boss pedals specifying the PSA type adapter operate at 9V like most other pedals. Boss pedals which specify the ACA type adapter operate at a higher voltage.
The Voodoo Lab Pedal Power 2 Plus is the only universal power supply available which will power any type of Boss pedal effect. There is a selector switch for each DC output on the bottom of the Pedal Power to select the correct voltage.
Short Circuit Protection
Each output on the Pedal Power 2 Plus is short-circuit protected. This means that if you have a short in a power cable, or one of your pedals malfunctions, the Pedal Power will temporarily turn off the power to that pedal. All other outputs will continue to function normally and the Pedal Power 2 Plus is not damaged.
Toroidal Transformer
Power transformers create an electric field that can cause hum and noise in your effects. Some effects, such as wahs, are particularly susceptible to this. A toroidal transformer has a specially designed core that greatly reduces this electric field. The Pedal Power 2 Plus uses this type of power transformer so that your pedal board is quiet.
Product Specifications:
Voodoo Lab Pedal Power 2 Plus Specifications
Input: IEC connector (120V 60Hz)
Outputs: Eight 5.5 x 2.1 mm barrel connectors (center negative)
Power: Selectable between [email protected] and 12.2V
Dimensions (W x D x H): 6 x 3.4 x 1.75 inches (152 x 86 x 45 mm)
Weight: 2 pounds (0.9 kg)
Special: Toroidal power transformer
Other: Auxiliary AC outlet (200 watts max)
Warranty: 5 years
Included are:
7 right angle 5.5mm cables
1 Line6 cable Red
1 3.55 positve middle cable
1 9V battery snap adapter
Two mounting rails and screws for pedal board mounting.
Description:
Warranty: 5 years
Included are:
1 Line6 cable Red
