Ok I was thinking about checking out attenuators today and when I searched the bay a bunch of volume boxes came up. I understand the basic concept of how both VBs and Attenuators work, and obviously attenuators work better because they cost about 10 times more. I find the seller descriptions of VBs confusing, some say they work as well as attenuators allowing you to crank the amp getting the overdrive, but lower the volume to reasonable levels. I tend to think (but I'm nowhere near an expert) that it goes in the effects loop so all it would do is make a sensitive volume knob less responsive and I couldn't get overdrive and low volumes.
So if someone would be kind enough to clear some things up...
Can volume boxes allow you to crank your amp (to get distortion) and have low volume levels?
If so, attenuators would work better, correct?
Are volume boxes usable on any amp with an effects loop?
I used the useful search function on the forums and searched volume boxes and not much came back, so sorry if this has been covered already.
Thanks to anyone that can straighten things out for me.
