charveldan
- Joined
- Aug 2, 2009
- Messages
- 1,278
- Reaction score
- 666
So straplocks that aren't straplocks really are straplocks ... hmm
They work VERY good....all I use on my guits... as long as the screws are solidly into the body (as they should be, whether using straplocks or not), then the Grolsch washers provide very good strap security. They may not look flash, but they just plain work...and that works for methey work pretty good![]()
NO ONE will care that you replaced the strap buttons. So go buy another set of straplocks and put that on your classic custom.
Another vote for rubber washers over the strap, but I found a 10 pack at Home Depot so I did the 3 guitars I usually keep out and have spares left over.
The problem for me with straplocks is they are not universal which limits their appeal to buyers.
Some time a ago I saw the perfect answer to this problem but it seems the company was under capitalized and could not get enough exposure to get their product widely known. It was basically a straplock strap -- not the ones with the shitty plastic clips to ruin the guitars finish. These looked like a normal strap but had a thin but durable spring loaded plastic latch enclosed inside the strap. It would take a close inspection to tell it was anything other that a normal strap but to put it on, you had to slide the latch to allow it to fit over the button on the guitar. When you released the slide the button fit into a groove in the slide and the strap would not come off without first sliding the latch open against the spring tension. Very clever, functional, required no mods to the guitar, didn't have exposed parts that could damage the guitar and they were no more expensive than some of the standard straps you see in every Guitar Center.
