dealmaker
- Joined
- Mar 5, 2010
- Messages
- 722
- Reaction score
- 330
So on both my boards the noise gates I have (MXR Noise Clamp and Boss NS2) have both "input/Output" jacks as well as "send/return" jacks.
Traditionally I have always used the Noise Gates at the start of the loop signal chain - and simply use the input/output.
On both my boards I separate my wah/distortion/pitch effects at the front of the amp - going to the pre-amp - and then all modulation effects in the loop. (with the noise gate)
I saw a band the other night and the guitarist had all 4 of the jacks on his Noise Gate connected - I had a quick look and from what I could tell it seemed like the Noise gate was part of the chain in the "front" of the amp - but was also connected as part of the send/return of the loop??
I'd always assumed it had to be one or the other - and not both - as I'd assumed you would get some sort of crossover between the two?? Is that right?...or can I put both the distortion/pre-amp as well as the loop through the noise gate????
Opinions please (don't want to pull all my boards apart without at least establishing I'm on the right track!)
Thanks!
Thanks!
