What's the scale length?
23.5" and you've got a poor-man's Byrdland!
But how do you get in there to work on anything? Through the pickup hole I suppose? Talk about building a ship in a bottle.....
You need to slay some Great White Buffalo with that beast!![]()
No. Do not glue the bridge to the top, they are supposed to be just sitting on the top. Once you get the intonation right, the string will hold it in place....The bridge was just sitting on top of the body, not glued down or screwed in or anything. I may hot glue it in place?
The truss rod is likely a 4mm or 5mm, but the hole is probably tapered, and ball-end allen keys don't work well.No center block, but there's a beam inside that goes from the back to the top underneath the bridge. The bridge was just sitting on top of the body, not glued down or screwed in or anything. I may hot glue it in place?
There's a truss rod, and it looks like it's an Allen head, but none of my metric or SAE sizes work and when I look at it close it looks like it's just a sleeve? sorry bad pic.....
There was also a loose wire in side, may be a ground. Everything seemed to work fine when I tested it.
Part of the answer to the "how can they do this so cheaply" is answered in your posts. You are doing a lot of the handwork that costs time and money, which the maker saves by having you dress frets, do setup, and repair slapdash wiring. Then, you can throw away the junk hardware for something more solid. And then the pickups. Maybe do some work on the finish if you find blemishes. Hopefully, you end up with a guitar you really like. There's really no mystery to the low prices on these. Robots, underpaid, unskilled assemblers, cheap components, cheap woods, and disregard for fretting, setup yields profit margin. And when you think of shipping and distribution, etc., it all ends up being a real penny-pincher of a widget-production operation. Making furniture, really.
Is that guitar on a flat surface? From that pic looks like a horrifying neck warp?
So far every metric guitar with that style truss nut I've worked on has used a 5mm Allen key.
I tried every method you can think of to rewire my MIJ es-175 style guitar and in the end I got it really quickly using my pinky finger through the f hole to hold each pot and get them into place. I first tried aquarium tubing over the pot shafts, then dental floss, then wire and every single time wires inside would get crossed! My pinky was the only finger I could fit without it getting stuck too badly.
Before doing my 335 style guitar I bought this thing from StewMac. I'm quite sure you could make one from a coat hanger, but I bought it during a sale and it sure is easier than having my finger stuck in the end of the f hole, lol!
- StewMac
www.stewmac.com
Using that I had the job done right quickly!
