closed_PaulSlack
- Joined
- Dec 10, 2010
- Messages
- 959
- Reaction score
- 497
Hi Chaps.
It's time to get cracking with a guitar I've been working toward for a long, long time now. I had a dabble with a 59 replica a few years ago and since then, have been learning and building up tools to make good the mistakes I've made along the way and put in to practice a lot of things I've learned mostly from this excellent forum.
My last finishing job on the Precision build got me motivated again and so I'm keen to finish off my collection of parts to try to build my most accurate 59 Burst to date.
I have some superb figured Maple and a lovely chunk of mahogany for the body and neck, which is already underway. Pics to follow.
Now, as I've never seen a 59 Les Paul in the flesh, let alone hold one, I have only managed to source parts using references from pictures I've seen here and elsewhere on the net. My hope, is that you guys can help me correct any parts that are not right or close enough, so that I can make any changes or replace parts for the build as I go along.
Here is a list of parts I have so far and your feedback on them would be greatly appreciated.
There are more to come, but these are all I had time to shoot last night.
Thanks for reading.
Here is a vintage correct scratch plate bracket with the accompanying screw set complete. I am told this version was used on most early models up to and beyond the 59. Though obviously not any longer.
This is the underside of the same piece:
Next up is a vintage correct jack cover in the correct material with the older stlye, more square corners than modern counterparts:
Here we have a "Bumblebee" (I have a few of these). Again, I can only go from photos, but the banding colours and size are exactly right with 59 shots I've seen.
Now, this might be where I need a bit of help. I've seen 59's with all kinds of knobs, but mostly top hat style. I have two sets. One is an aged set of clear amber top hats and the other is this. Almost identical in every way except for the silver cap with writing on. Which do you think is most accurate?
Switchcraft switch, which will be getting the age treatment.
And the amber tip, which again, requires a little finishing to smooth out a casting mark. Not sure what it's made of but it's not plastic. It's hard as rock!
Thanks for reading.
