TSL122 and MC212 Cab?
Nicky
On The Road Less Traveled
My TSL122 is a 16 ohm 2x12 combo. My cab is a Marshall MC212 2x12 that runs at 8 ohms in stereo, or 4 ohms in mono. Can I run both the combo and this cab together? Here's the back of the combo. It's running at 16 ohms as shown though the dedicated 16 ohm output jack.
If I plug the combo speakers into one of the other outputs and the 2x12 cab through the other, do I set the switch to 4 ohm or 8 ohm? Can it work without problems or issues? Thank you!
Nicky
Figured it out. Rewired the cab speakers to serial = 16 ohm cab. Plugged the "new" 16 ohm cab into one speaker out, and the internal 16 ohm speakers into the other speaker out, flipped the amp's speaker out switch to 8ohm.
16 ohm cab + 16 ohm combo speakers (in parallel) = 8 ohm resistance.:)
mojofilter
Very nice! I have the same amp,now you have figured it out for me! thanx!
