shickma0
- Joined
- Apr 24, 2017
- Messages
- 243
- Reaction score
- 179
Hi all,
I’ve recently picked up a (partially) mint 2017 Mike Dirnt road worn signature bass in Mary Kaye with a rosewood board. Unfortunately the action is pretty sky high after acclimating for a month. It had a mike dirnt signature squire neck on it when I purchased it which I don’t mind (even dirnt himself used a squire on stage back during the trilogy and even during the awesome as **** live album). The neck is in fair condition with a bunch of dings and some fret wear however the truss rod is stripped. It looks like someone’s used a customary sized Allan key in the metric truss rod nut. I’ve tried the rubber band trick, the screwdriver trick and some of stew macs truss rod rescue wrenches. No go on any of them. If any of you had suggestions on how to get the nut out so it can be replaced that would be much appreciated. If it’s stuck then no big deal, I’ll just get an all parts replacement neck (the whole bass only cost me $600 and all the serial numbers match and are correctly dated so it’s legit and these basses retail at nearly 1200 USD so I’ll still come out way ahead if I replace the neck) however if I could save a few hundred it would be nice even nice. Thanks. -S
