I do.
So are you just lifting the nut side about 1/8" with some scrap and running it through with a feather board? I have a 3/16th spiral bit that should work well with 3-4 passes.
I have a sled for both curved and straight truss rods and use a fly cutter.
The latest neck I used a regular router bit and stew macs da truss rod.
I am at work so can't get a better photo, but here is my first really crude set up and sorry for the crappy photo. I have better jigs and a genuine table I use now.
Started another "other single cut" yesterday. Considering using a router table to cut the truss rod channel.
Anyone give this method a go here?
BTW. Happy Thanksgiving weekend to the other Canucks here. Gobble.
I have a good solid fence built into my router table so I am going to use it . Thanks for your decisive reply!I used the router table.....and will be using it again and again. Set up a fence clamped to the table at the right distance away......attach 2 small wedges to the nut end (double sided tape for mine) and rout away.
A sharp bit is great here too. I had a single sided bit that was getting blunt and it was always trying to drag the wood off the fence.
I used to use my router table, but it was time-consuming. I found some guy who runs Maximum Guitar Works. He makes a truss and carbon rod jig that works AMAZINGLY well. It cut my work four-fold, easily: https://maximumguitarworks.com/products/truss-rod-template
Was worth every penny. I already had router bushings, so I was able to get right to work. All 3 channels done in about 20 mins or so. One of the best tools I've bought.
(No affiliation)
<high-pitched, squeaky voice> What?!?! <high-pitched, squeaky voice>
I use my router table and its probably one of the fastest, most fool-proof operations of an entire build
Takes me 2 minutes to set up the fence, and another 3 to route the channel, and it’s perfect every time. Change the bit, move the fence a bit, and route both carbon fiber channels in another 5-10
Whats are you doing that’s time consuming?
I typically do - just a standard slot for the DA rods. The last neck I built, I cut the channel with an old Stanley 45 combination plane. That was kinda fun.
The router table and fence method seems pretty decent but I'm interested in seeing how people do it with a combination / plough plane. There's a lot to be said for methods that are quiet and create shavings instead of fine hazardous dust, your neighbours and lungs tend to prefer them.
Kind of like using air conditioning.....we don't "have" to use it, but living in Florida you can get your you-know-what I'm using the heck out of it, lol.Frankly Id be surprised to find anyone that would prefer to do it that way unless it was simply that those were the tools they had at their disposal.
There might be a few that get something out of doing things "the old fashion way"
Theres are few hand tool build threads on the forum that you might like![]()
With a combination plane really only would work well with an angled headstock, because you need the full length of the cut to work. The way the plane works, the sole needs to ride out ahead of the cutting iron, and that isn't really feasible on a Fender-style neck.The router table and fence method seems pretty decent but I'm interested in seeing how people do it with a combination / plough plane. There's a lot to be said for methods that are quiet and create shavings instead of fine hazardous dust, your neighbours and lungs tend to prefer them.
