Hey guys, I have an Orville by Gibson 57 RI that I’m trying to set up in a low tuning (c standard). I have the guitar set up as I want ... well, almost. When intonating the G string im running out of wiggle room on the saddle as I try to flatten the pitch. The relief is set as I’ve always had it (0.10”), as is the PU height, bridge height etc. The nut slots are wide enough as well for the 12s I’m using. I verified this with the guy at the guitar shop.
He says these bridges were not designed to be used with low tunings. In which case, can anyone recommend a suitable bridge for this model (approx 73.6mm between posts) with saddles that extend beyond the standard specs (mine travel approx 6.5mm). He was not helpful in this regard.
