johnh
- Joined
- Oct 14, 2011
- Messages
- 185
- Reaction score
- 81
A lot of people try treble bleed circuits and end up not liking them, because the component values are not right. The best version for keeping a consistent tone as you roll down is a cap and resistor in parallel. If you are using a 500k volume pot, a 1nF and 150 resistor is the best based on analysis, for keeping a consistent tone in the range from about 4 up to max. If you more usually turn down below 4, a slightly smaller cap is a bit better, 0.68nF or 0.82nF. If the resistor is not there, or too large, the sound thins out too much at low volume. Then, by ear, you might find your prefer a step or two change in values.
The parts are so cheap, and easy to try on an LP, that it is worth a shot.
