Traynor YBA 1 Mod1 blowing fuses
  • Thread starter sibyrpunk
sibyrpunk
Hey guys, hope you can help me out. At rehearsal today I turned the power on my amp waited a minute then switched off the standby, amp played for a few seconds then the pop fuse blows. Throw in a new fuse and same thing happens again.
What simple things can I check or should I just take it to my tech.
Thanks Joe :(
Soul Tramp
Speaker Snob
Be sure you have a speaker connected. Possibly bad power tube.
It needs to go to a tech.
sibyrpunk
Tried a different power cable and it was connected to the cabinet at the correct ohms. I'll try a different pwr tube and see what happens then off to the tech.
Thanks for the quick reply.
Soul Tramp
Speaker Snob
Watch the power tubes when you turn it on and see if either red-plates.
kevinpaul
Install a new fuse, make sure you are using the proper cable for the speaker. Use a surge protector. That will help you to avoid any power spikes that can make a fuse pop. The amp turned into a fuse eater do have it checked out.
al30
Pull the power tubes. Install a new fuse. Turn the amp on. Did the fuse hold? Yes? You have a bad power tube(s). No? You've got other issues.
sibyrpunk
Thats exactly what Gary at Traynor said to try, will do it when i get home.
Thanks
sibyrpunk
Ok, pulled the pwr tubes and the amp stayed on gonna order a new set. Thanks for all the help!
