Transtint burst, grain raising question
waygorked
I'm about to do another hand-rubbed burst on a maple top with Transtint dyes. On my last project, I wetted down the top with H2O to raise the grain and sanded it back to 320. The burst took something crazy like 20 dye coats to get it where I wanted. I was using water to dilute the dye, and by the end the top felt pretty rough again. I had to work quite a bit harder than I wanted to get the TruOil coats glossy in the end, although I was very happy with the ultimate result.
I know the easy solution is to spray a lacquer burst, but I have a serious lacquer allergy, and am committed to sticking with the dye burst and TruOil process. Any suggestions to limit the grain popping back up would be appreciated.
jkes01
Try using denatured alcohol for thinnng the dye.
