That's a great question.. I wonder if anyone here has ever done that?
Originally Posted by nitrodave08![]()
I wonder if the single screw would be enough. Drilling the hole would not be hard to do. I would do it just for looks. I don't change strings every day so the quick change in not a factor.
I ordered the Gibson Vintage Nickel Machine Heads from sweetwater, should be here weds or thurs, I let ya know
The screws on the back keep the tuner body from rotating
I doubt that using one screw on the back rather than two would make a difference
Grover uses just one small screw, so the Kluson type can too, if you don't want to drill the second.
I did that... The only reason I added the second hole was because after a while I decided I did not miss the Grovers, and would not be going back.
Worked fine. I just added the second because the little empty hole on the back bugged me.
But you should be fine. The Grover hole lines up perfect with the bottom hole of the Kluson style.
OK, here it is. It wasn't too bad, but I suggest you get your pilot hole the right size for the top screw or you will strip the screw head trying to get it in (yes I did)! fortunately I was able to back the screw out and find a new one at my local hardware store. The old Grover screws do not fit through the new tuners. I love the tonepros cant believe I waited so long to do this.
You may find the Gibson brand are not a good fit. Grovers are 25/64" or 10mm I think and IIRC gibson brand are smaller (if you got the press in bushing type) and so may be loose in the holes on the headstock which would be a problem
I guess you'll have to see when they arrive
The Tonepros/kluson KB3 are a drop in fit with no modification needed and line up with existing screw hole
If you choose not to use a second screw the KB3 will still work but I prefer the extra stability of two screws for this design of machine head
I will be doing the same thing, with the waiting.
I can't see why someone would want to replace locking Grovers on a new Trad Pro II, I have a Trad Pro and the locking Grovers are great, no need to butcher a great guitar or take a chance to scratch the finish when the locking tuners on it already are GREAT.
