Martin Kay
- Joined
- Sep 20, 2010
- Messages
- 5
- Reaction score
- 2
Are the various pole pieces on a humbucker supposed to vary tonally? By this I mean should the third string be more trebly than the fourth string which might be more bassy.
I was aware of that...I asked if the tonal value should vary, ( for instance my E,A and D strings are much more bassy than the G,B.E strings- is this normal?The adjustable screws are meant to control level, not tone.
Thanks so much for posting that very helpful and informative guide, however it was not output volume I was asking about but tonality. The three lower strings EAD sound way more bassy than the GBE strings- its this normal?Here's a great guide on how to set up pole piece height.
How to Properly Set the Pole Piece Height on Humbuckers
Changing the pole piece height in your pickups can dramatically affect your sound, so I've created this guide to explain how to best set the pole piece height on standard humbucking pickups. This simple adjustment can do wonders to improve clarity and balance the string-to-string output of your...www.mylespaul.com
Yes - they are a lower frequency (pitch). If they are louder than your high strings, lower that side of your pickup.I was aware of that...I asked if the tonal value should vary, ( for instance my E,A and D strings are much more bassy than the G,B.E strings- is this normal?
The wound strings tend to have less harmonic content with your typical humbucker. Especially the transients. Single coils and humbuckers designed to sound more like single coils give you more of that piano like wound string tone.Thanks so much for posting that very helpful and informative guide, however it was not output volume I was asking about but tonality. The three lower strings EAD sound way more bassy than the GBE strings- its this normal?
