Got the Epi Les Paul rewired with vintage braid. Much happier with it. We live in a very old apartment with dirty wiring (which is being kind.) The vintage braid seems to help with cutting some of the noise.
Did the SG yesterday and nothing seemed to go right. Shouldn't pick up a soldering iron when you're tired. Made all kinds of stupid mistakes.
Today went as well as yesterday did poorly. Everything worked right first time out, with the exception of the jack (which is soon going to be replaced with a switchcraft.) Damn, the Les uses a lot of wire! SG was all done using 3 feet (including soldering it from the pickups back as leads) - whereas the Les Paul used just over 8 feet. Lots of wire to run from the switch back to the controls of the LP.
If anyone new out there is considering swapping out the wire in their guitar, 4 feet of braid for a SG is plenty, 10 feet for a Les Paul will give you a bit left over.
(All wires changed to vintage except for bridge ground.)
I also soldered the braid from the pickups to the braid wire from switch (to jack) to ground the pups. Saved the effort of soldering them to the back of the pots. Just found it easier, made a nice neat job, and it worked just as well. One of the big advantages to using metal braided wire.
