Three pice body question
Hozy
I have a 81 wine red custom , and was wondering if I should be able to feel the seams on the three piece top ? I can see them and feel them. Any information would be great,thanks.
judson
pics would be helpful..
seeing them is normal
feeling them isnt normal unless the finish was stripped and they are starting to separate
oh wait you said it was wine....could be the finish is cracking or the wood separating/moving a bit
grumphh
No you shouldn't.
Doesn't mean that it can't happen, but on my '71 and '79 LP's i can neither feel nor see the seams on the top.
(Of course on the SB '71 (in the avatar) i can see where the three maple pieces meet, but there is no indication of that on the laquer surface.)
mudface
Boo Bee
I have 1978 Custom....see them? .....YES.....Feel them?....NO
On my 1977 Custom i can't even see them.
Heppe
As stated above, I can see the seems on my 78 std but not feel them.
kakerlak
Whatever it is about that era, yeah, you can sometimes feel the glue joints on the top and at the wings of the headstock, etc. Often times, it just seems that the wood has shrunk/settled a bit and a butt of a ridge remains along the joint. And if everything is still perfectly tight, then NBD. That having been said, I have seen ones that have started to warp away a bit and actually separate. Unless there's a water damage issue, something that old is probably stable at this point and those seams aren't really structural. As long as that center section of the top is securely glued to the back, it doesn't really matter what's happening either side of it the the other two pieces lie.
All that having been said, still something that poses at least a little extra depreciation over one with nice tight, clean, smooth joints throughout.
Hozy
Thanks for your information, if it wasn’t for the flaw with the seams it would be almost in perfect condition , I have no idea what it would be worth.
