The P-Rails sound like a really versatile pickup... especially with the triple shot rings...You can cover a lot of ground with a good Les Paul and a good Tele.
For a while my "Fill in the gaps" guitar was a PRS SE Custom with a set of Duncan P-RAILS (with triple shot mounting rings).
It was 24 frets for the few times I wanted that. It was P-90s, Hot Rail, Series HB or Parallel HB (for each pickup independently) and had a decent trem when I wanted that.
If someone wanted only one guitar I wouldn't suggest a Strat but if someone wanted a "Guitarmy" I think a Strat has a place in it.
Thanks for your suggestion!If you’re leaning toward a Strat, I would take the time to learn beforehand how to make one sound good so you don’t get frustrated and take it back. I previously bought one, but turned it over quickly because it wasn’t just plug and play like a Les Paul with almost any kind of amp. But now I have two Strats and another HSS.
It’s a very different animal and what works for an LP and even a Tele isn’t necessarily the case with a Strat. As an example, high gain just doesn’t work well with Strat single coil pickups, but varying levels/types of fuzz, some compression and modulation work great with them and you can do some fantastic things with one once you get used to it.
The one thing I don’t have is some type of filter on guitar - that will probably be the next one I get.
ThanksI have the Les Paul standard, the Stratocaster. The third would probably be expected to be a Tele, except I have a Deluxe 70s that's really its own thing. I have a CV50 Tele, which is a fine guitar and I've practically worn the frets off of it. That guitar may find its way to a newbie someday, who will hopefully learn to love and play the guitar. Should I find the Tele that grabs me and says "Take me home", the Deluxe is fair game for trade or sale.
I am trying to get to three electrics, one acoustic and a bass.
GAS level risesSomething like this: View attachment 662321
Thanks for your suggestion!the suggestions for P90 make sense
in which case, Gibson ES 330 , or a Casino
then maybe a PRS Variant of the previous suggestions?If we talk tone wise, I agree with all previous suggestions.
If we talk about playability and feel, PRS is unbeatable.
Thanks Janning! Whoa.. This one is out of the boxChange your 1 and 2 to an Ibanez Prestige rg5170, number 2 to an Ibanez j custom and for the third? An EVH CUSTOM, (it like a love child of a strat and Les Paul it’s best of both, then on all 3, Optima gold strings. Then unless you’re so pro making 10K a. Gig, , Bugera. AMP, 120 watt 333xl infinium or the Trirec infinium … forget that Celestion hype bs, get couple $100ish 12” in a 2 by 12… prepare for hearing loss and orgasmic sound …. And now comes miller time… almost forgot , also screw xvive crap wireless ….for half’s the $ get two pair greteria
This is an interesting thought about unpotted pups. thanks for the suggestion!The bare minimum guitar I need for work is a Les Paul, Strat or Tele (I use a Strat that also has Telecaster wiring) and a hollow body like a 335.
I recommend unpotted pickups to take advantage of the hollow body characteristics.
Good Luck!
ThanksI agree that you miss a guitar with tremolo bridge,
Additionally a semi hollow Rickenbacker? (don't know exactly what makes them sounds differently)
I see what you did there! 2 of 3 Problems solved. fixed bridge - check.... quack - uncheck yay
Sweet! sounds like a good trinity of electrics... why no SG with p90s?I also have a Gibson Les Paul Standard and a fender American tele. I went with a 61 reissue Gibson SG for #3 and then a step further 4th was an acoustic Martin 000-15M. I’m done. Thank you good night
335s are semi hollow. ES 135 is hollow.The bare minimum guitar I need for work is a Les Paul, Strat or Tele (I use a Strat that also has Telecaster wiring) and a hollow body like a 335.
Good Luck!
go gretch!!Hello
What would you consider the ideal third electric guitar, if you want to cover as many tones as possible.
At the moment I own a
Fender Telecaster with three Single Coils (Tele Neck+Bridge and Strat Middle)
and a Gibson Les Paul with two Humbuckers.
With these two guitars one already covers a whole range of sounds...
What guitar model would be the third Guitar, that would be different enough to both of these?
Which guitar would sound totally different to the Tele/Strat and Les Paul Sound?
Semi Hollow with TV Jones?
PRS with a 25" Scale Length?
SG with P90's?
Danelectro with Lipsticks?
Let me hear your ideas!
Would love to hear your opinion.
Thank you.
Merlyn
For me being a 70s rocker growing up listening to les pauls, strats and tele's through a marshall. It would be just that Les paul, strat and tele. Being the les paul is and will always be my farvorite. I have three reissues a 60s with humbuckers, a 57 black custom with humbuckers and a 54 with the staple pickup in the neck and a P-90 in the bridge. I've tried many different gibson hollow-bodies but none stay'd around like the solid bodies. I'ver tried several SG's but again none stay'd. So it's early fender and marshall clean and plexi overdrive.Hello
SG with P90's?
Thank you.
Merlyn
@Leee @NotScottThis sounds interesting... thanks for the suggestion...
Stupid question... just curious... but how do you think a filtertron pickup will sound in a solid body guitar like a Les Paul? Will it sound similar to a Gretsch?
Yep, as did Billy Duffy from The Cult and Brian Setzer.the late malcom of A.C D.C sure knew what those pups could do!!!
here are my 2 Gretch guitars i own..need i say more..rock on! and yes,..thats a Brian Setzer model..and a Billy Gibbons modelYep, as did Billy Duffy from The Cult and Brian Setzer.
