- Joined
- Jan 14, 2010
- Messages
- 2,887
- Reaction score
- 1,250
I don't agree with this at all. The single most important element in the design of a speaker system, be it hifi or guitar, is the driver. I believe guitar amp manufacturers put great thought into the drivers(s) that will be used.
It's for this very reason a company like Weber offers over 170 different speakers.
Granted the cabs are not designed at Lincoln Labs, but they don't need to be for a guitar speaker system. But despite this there are many guitar speaker cabs designed for specific a voicing and/or purpose.
I'm afraid I'll just agree to disagree on this one for a thread focused on attenuation.
I'm aware of the various driver manufacturers and their offerings. Ditto most of the cabinet manufacturers. In the main, I think that most offerings from most manufacturers are simply duplications of traditional cabinets with a generally-custom-accepted set of speakers tossed in. I believe that most of the effort has been in the carpentry and covering department and not for "voicing." Manufacturers mostly use brands and specific speakers (Vintage 30's, greenbacks, G12-75s) because customers recognize them and are comfortable with them. They'll occasionally use others (Rocket 50's, for example) because they're far cheaper. Specs tend to duplicate each other; a 4x12 is usually around 30 x 30 x 14, give or take. It's not because it's the best possible configuration for four 12" speakers, but because it's a familiar and traditional shape.
Sort of yes, sort of no.
No (lemme repeat that...NO) attenuator in any of the lists above allows the interaction between output transformer and speaker voice coil to happen unobstructed. No attenuator in any of the lists above maintains the tone of the amp/speaker combination; they all change things. If you LIKE what they do, you're in good shape. If you don't, then you're off and running trying various attenuators and various EQ setups to try to adjust things to get back to what you like. And the amount of tone change varies according to the amount of attenuation necessary, so you're constantly chasing EQ.
The Fluxtone is the only system that puts nothing between the output transformer and the voice coil of the speaker.
The first time I heard the fluxtone was at the LA Amp Show several years ago. They had two cabinets set up, one with a standard speaker, the other with the same speaker, but with the Fluxtone setup on the back. They switched back and forth for a bit, and it was obvious that the two speakers sounded identical. They cranked things up (it gets LOUD in those airport hotel rooms, but the additional sound proofing in each room necessary to allow people to sleep under an airport flight path is why the amp show is held there). And then the fluxtone rep began to dial the thing down.
The tone stayed the same, but things eventually got to the point where you could hear the sound of jaws bouncing off the carpet and the occasional "no WAY!" It's 25 dB of difference (roughly the equivalent of taking your 100W amp down to 1/2W).
The ONLY real problem with this approach is its expense. It's prohibitive to put a quartet of these speakers in a 4x12 or a 2x12, no question. But if you're recording or practicing, or even doing a gig where stage volume is a serious issue, why would you be working with those larger speaker cabinets anyway? I have, for example, one of the loudest four EL34 amps I've ever heard. It's a 1x12 combo that usually houses an EV and between the bigass Mercury Magnetics transformers and the magnet on the back of that EV, it's insanely heavy for a combo. It's run pairs of 4x12s to ear-melting levels for gigs, but it's crazy loud just on the efficient internal speaker as well. I tried it, cranked, with a Fluxtone speaker based on the EV in an open-backed cabinet. Then dialed it down as far as it would go. Fletcher-Munson aside, there was all the good stuff but at a volume that would allow a muted conversation. We put it in a room and put a mike on it (try this with your attenuators) loud, dialed down, and then on the internal combo speaker. The obvious differences were between the Fluxtone and the internal speaker (this speaker was the original from 1988), but between the cranked Fluxtone and the dialed-back Fluxtone, very little, approaching nothing. Try that with an attenuator and see what you get.
