cooljuk
Transducer Producer
- Joined
- Mar 11, 2009
- Messages
- 17,742
- Reaction score
- 27,072
We as musicians often see DCR listed as the only, or one of few, specifications given for a guitar pickup. This is something of a bad habit of the guitar and pickup industry that has lead to a bad habit of relying on that figure by musicians.
I'd like to throw out some examples to help clarify the significance, or lack of significance, of DCR in a guitar pickup. These are real actual measured results from coils I've wound, I'm not speculating for the sake of an example.
Coil A:
Wire Used: Plain Enamel @ 1.7180 Ohms/ft
Turns: 6000
DCR: 4.36k Ohms
Inductance: 1271.1 mH @ 120 Hz / 1504.6 mH @ 1kHz
Coil B:
Wire Used: Plain Enamel @ 1.5767 Ohms/ft
Turns: 6000
DCR: 4.16k Ohms
Inductance: 1306.1 mH @ 120 Hz / 1310.1 mH @ 1kHz
Coils A and B have the exact same turn count, both are wound with what would be considered AWG 42 wire. The DCR is quite different, but the sound is nearly the same. A humbucker made of two A coils would have a DCR of 8.72k Ohms. A humbucker made of two B coils would have a DCR of 8.32k Ohms, but these two humbuckers would sound just about the same as each other.
Let's look at another pair made with the exact same wire spools:
Coil C:
Turns: 5300
DCR: 3.49k Ohms
Inductance: 996.7 mH @ 120 Hz / 970.6 mH @ 1kHz
Coil D:
Turns: 4800
DCR: 3.49k Ohms
Inductance: 827.3 mH @ 120 Hz / 826.7 mH @ 1kHz
With coils C and D you will see that the DCR is exactly the same! ...but look at the rest of the figures. The turn counts, and accordingly the sound, are VERY different! 500 turns per coil difference is significant.
Now take into consideration that these are individual coils of a humbucker. When you add the two coils in series (like a humbucker typically does) you will double the DCR, and the DCR differences. In the example of coils C and D, if you made a humbucker with two C coils it would read 6.98k total DCR and have a total of 10,600 turns. If you made a humbucker with two D coils it would also read 6.98k total DCR but have a total of only 9,600 turns. Two pickups, both wound with AWG 42 wire with exactly identical DCR and 1000 turns wire of difference. They will sound VERY different but your multimeter or a manufacturer's stated specs won't give you even a clue to that difference.
Want to talk about magnets under all these coils? That changes the sound even more, without changing DCR one bit. Can you imagine how the two humbuckers made from coils C and D would sound if one had an A2 and another had an A5? The DCR wouldn't account for any differences in these two VERY VERY different sounding humbuckers. This is scraping the tip of the iceberg. Steel alloys, mass and shape of pole pieces, coil patterns and shape, turns per layer, wire tension, wire type, insulation thickness, charge level of magnets, magnets of the same type and charge from different foundries and lots - all of these are just some examples of variables that significantly alter the sound of a guitar pickup, but do change a pickups DC resistance.
I'm not claiming to be the authority on the subject or that this post is all encompassing by any means whatsoever. What I do hope it will do is simplify, in a few easy examples, why DCR should not be considered definitive of a pickup's voicing to anyone who can grasp some basic figures and concepts. The guitar and pickup industry has used DCR as a crutch for decades and misinformed the public in doing so. The reason for this is not malicious, but because there is no one figure, or even set of figures, that will define a pickup's voice absolutely. I hope this helps open some minds as to how things really work.
Coil A:
Turns: 6000
DCR: 4.36k Ohms
Coil B:
Turns: 6000
DCR: 4.16k Ohms
Coil C:
Turns: 5300
DCR: 3.49k Ohms
Coil D:
Turns: 4800
DCR: 3.49k Ohms
