The Les Paul Headstock Tilt
icantbuyafender
Not sure thread was to be: rant, admiration or honest inquiry...
Paulinator
FFWD to 9:28
[ame="http://www.youtube.com/watch?v=VbU1R4KDymw"]Gibson USA Factory Tour - YouTube[/ame]
paulgibson
chasenblues said:
Honest inquiry that almost got off track. Course not all LP(or other style of guitars) "type" guitar necks/headstocks are made from a single piece of wood,Some are constructed using a scarf joint.
IMAGE#1
LP set neck headstock break
Would the scarf joint be more prone to break as opposed to a single piece?
Posted from Mylespaul.com App for Android
chasenblues
I don't know,There's more surface area with the two pieces glued together. Than at the nut/headstock area where it seems most of the neck breaks on LP's occur. :dunno:
Shawn Lutz
They bend the mahogany trees 17 degrees from sticklings and the just grow that way ;)
Farquad
quite the opposite. The single piece of wood has a weak spot at the tilt where the wood fibers are the shortest.
The scarf joint takes that weak spot away, and has longer wood fibers.
Plus the bond between the glue and the wood is stronger than the natural bonding of the wood fibers.
Another way around this weak spot is the volute.
paulgibson
How would I know what type of joint is in my 2013 trad? Do they use the scarf joints on the more expensive custom shops? Wonder why Gibson did away with the volute if it ensured greater stability and less headstock breaks
Ermghoti
All USA gibsons are one piece/carved necks, only Epiphones get scarfed.
The 50's Gibsons did not have volutes, therefore the Gibson customer, who is largely buying the sense of tradition that emanates from that era, sees them as a downgrade. The 70s volutes were, in my opinion, a little clumsily executed, compared to others I've seen, so that's probably part of the backlash.
People didn't like the volute as it wasn't the way it was done in the 50's......like all the other innovations in the neck area during the Norlin period (multi-piece glued necks and a move to maple).
Scarf joints are a good way to tell a fake LP.
