Wow, just Wow!
Hi,Sooo, top is glued on, I've learned from my first builds that you don't need so much glue that it flows over the whole floor, so this time not so much and only a little bit squeeze-out.
I sorted the binding and yeah, fretwire arrived yesterday!
So now I need some advice from you guys. I've read a lot about this wire but I don't want to do a mistake now.
As Sully stated SS fretwire should have the same radius than the fretboard, I did mine with the common 12", and the fretwire came pre-bent in ~10".
I added a pic how it sits on the end of the fretboard, flush with the board on both sides and only a little bit higher in the middle (and it's really only a little bit). Does this work with SS or is it already 'too much' bent (maybe just a dumb question because it follows the fretboard radius pretty close?)? I don't want that it jumps out of the slot in the middle one day. Sorry, I guess I'm just too fussy with these things...
Thanks in advance for any input.
