My '68 GT has a pretty substantial neck. At .89 at the 1st with some shoulder it feels more in between a '59 (less shoulder) and a '58 (a little more depth on my '58).
If you're looking for R0 neck dimensions the '68 isn't going to be there. If R8 and R9 dimensions work for you the '68 will do the trick.
Personally I really like my '68 GT. I may get a Custom soon.
Happy hunting!
Thanks, Dan - R8 and R9 necks are my favorite carves...though, as an SG fan, I can also get along with some slimmer necks, as long as they're not too skinny (my 2019 SG '64 RI is perfect).
2015 onwards 68 Custom necks are nowhere near an R8 and thinner than an R9.
That's not my experience. My '68 is a '19 model. Some older '68s had huge necks. The newer '68s aren't as large but they are no where near R0 spec.
The 2020 '68 Custom I'm eyeing now is also .89" at the first. I've seen listed specs as low as .86" on newer '68s but those are outliers.
Gibson uses CNC then final hand sanding on their necks. Most necks are going to be rather consistent in their size.
The neck is thinner, somewhere between an R0 and R9.
Anybody got the impedances of the '68 Custom Buckers?
Thanks for the info.6.8k both bridge and neck on my '19 model. They are the lowest output humbuckers that I've ever used.
Do you like 'em? Are they very bright?
