Telegib Wiring Question
King Minimoose
I'm thinking about doing a MJT telegib build; pretty much making my own Nash T 2HB. (My dad has a telegib that is heavily inspired by Jeff Beck's so I want to do something a little different to his). My question is what kind of pots would I use? Since there will be two humbuckers, I would assume two 500k pots but looking at the Nash it apparently uses a 250k tone pot. Any advice or insight would be greatly appreciated.
MATTM
MSSCGuitarWiring.com
I’d recommend 500ks in both the volume and tone.
jonesy
GLOBAL WIRING GURU
MLP Vendor
500k volume for sure, a 250k tone pot would help to keep it from being overly bright.
King Minimoose
Thanks. I would use a .022 cap, right? Also, any idea of how I would wire it? I can't find a wiring diagram for a telegib anywhere.
somebodyelseuk
Probably same as a Telecaster, just using different value pots and caps.
FWIW, I built a HSS Strat with stacked coil singles and SD 59, back in the 90s, with a master volume and tone. I just used 500k pots and a 0.022uF cap wired as per a Tele. Not excessively bright.
