HardCore Troubadour
- Joined
- Nov 17, 2012
- Messages
- 10,843
- Reaction score
- 10,647
Tama HP910LWN Speed Cobra Double Bass Pedal | Reverb
Tama HP910LWN Speed Cobra Double Bass Pedal on Reverb.com
This set of Speedcobra 910’s are in excellent shape, everything works as it should, with little to no wear.
Carry case is included.
You won’t find a better deal on these.
MLP price is $350 shipped/PP.
TAMA HP910LWN Speed Cobra Double Kick Drum Pedal Features at a Glance:
Wide baseplate and frame for exceptional stability
Para Clamp II Pro keeps your pedal flat on the floor, regardless of bass drum angle
3-piece hinge construction with hinge guard block for long-term durability
Fast Foot pedalboard design accelerates the power and speed of the beater stroke, requiring minimal physical effort
Smoother playing surface reduces friction between foot and the footboard for precise control and flexibility
Recessed setting strikes a balance between natural feel and lighter action
Ultra-tough Fastball Bearing (the same kind of bearing mechanism in high-end automotive ABS systems) produces super-accurate rotation
Round LiteSprocket provides natural feel and smooth action while decreasing weight by 40%
Super Spring requires less exertion in the beginning of pedal action, allowing you to play smoothly, without sacrificing impact
Cobra Coil steel spring returns footboard to its original position with each stroke
Vari-Pitch Beater Holder allows you to adjust the beater angle independently of the footboard angle
