Azaril0000
- Joined
- Mar 23, 2010
- Messages
- 22
- Reaction score
- 0
Hi all,
Bit of a newbie when it comes to string gauges and technicalities of it all, but I just wanted to confirm with the community about something I was adviced by a guitar tech.
So I bought Les Paul Traditional last year (Feb) and never needed to change the strings until recently. From looking it up, I understand the standard stock string gauge that comes from the factory is 10's, from Gibson's own string brand. Am I right assume they are 10? or are some 9?
I recently bought a set of DR Pure Blues Strings 10's (and 9's for my strat). Phoned up a tech I have gone to a couple of times in the past to confirm if stock Les Paul's come in 10's. Here's what got me worried. He said even if its the same gauge, it could still effect the tension of the neck, if the strings are a different brand, and could cause neck warping. He said without a proper setup (As this les paul is going by the factory setup and strings at the moment), there could be some damage to the neck if I put 9's or even different branded 10's gauge on.
So what do you guys feel about this? Is it as "serious" as it sounds, should I hold off changing the strings until I take it to the tech for a setup? Does the Truss rod need to be adjusted even when moving brands of the same gauge due to the tension? It might sound silly, I apologize if it does, I just don't want to risk any damage, but don't also want to spend any unnecessary extra money.
Thanks!
Thanks!
