Ole'Lefty
- Joined
- Oct 25, 2008
- Messages
- 5,211
- Reaction score
- 1,736
I had always wanted a hardtail Strat; just hate Fender trems- don't know what PRS does to make their similar 6 screw work so well, but they patented it. So, I got a loaded Robert Cray body in beautiful dark violet- custom shop electrics.
I installed one of my ebony FB necks- got so lucky;angle perfect, relief came in with stringing to staggered post Sperzel lockers I installed. Still use winds downward, even with the lockers. New Elixir .009 to .046 strings. Intonation is close but not truly set yet. Action height is perfect and frets cleanly all the way up the neck. It has the best chime that goes angry as desired with P/U selection and tone adjust. Sounds perfect doesn't it?
Problem: The treble "E" does not have the bell quality unfretted-all other strings do. As soon as I fret, it sounds great, like all the others. So, I figure the nut slot. OR since with staggered posts, there is no tree. I put some downward pressure on the string with a screwdriver behind the nut with no improvement ( kind of like a tree would) So, now I am focusing on the nut, with my thinking, slot angle wrong- perhaps take-off point is wrong or angle of slot is clearing the front edge of the nut and string take-off. Using magnification, I could not perceive a visible gap at that south side of the nut. I did one gentle stroke in the slot with a .010 S-Mc gauged file with no real change, but it was a very hesitant stroke ( it felt like it is slotted for .009, which is why I was hesitant). I did not go looking for my gauged saws because I can't recall if they go thinner than .010. I raised the pick ups at the treble side and it perked up but still some mud.
Before I really go after the nut slot, I am asking for input- as you know, a string to nut contact point can be off by an invisible gap and change things. And, maybe on this guitar, staggered posts or not, this guitar needs a tree. I would just start serious but careful filing but for the perfection of everything else. This is an impressive guitar with all of the good things in Fender single coils there and this is one of my necks with ebony that got the soaking CA treatment and vibrato with the finger is amazing and it chimes or bites forever, even through my little Peavey "Backstage II."
My mind is totally open here- I trust you guys and though I have "built/assembled" a few Fenders, and setup more, I am far from expert with them. Thanks!
Please offer your thoughts? I have to grade 18 long essay tests for tonight, so I will be away from the computer for awhile and thus, won't immediately see your suggestions.
