SamsDaddy
- Joined
- Dec 13, 2007
- Messages
- 226
- Reaction score
- 0
Hi Guys - I have been noticing annoying static pops on my R8 lately that are bugging me. I think they have always been there, but I am just now starting to get annoyed by it.
I searched a little and found some hits for reducing hum, but nothing on static pops. What happens is, I play for a little bit, then maybe take my hands off the guitar, and then when I touch the strings again, I hear the static crackle through my amp.
I recently put in the pots and caps, but I had the static problem before that with the stock electronics.
FWIW - I do have hum/buzz when I am not touching the strings and it goes away completely when I touch the strings. I am not concerned about that kind of buzz, but just in case it helps diagnose the crackle problem I thought I would mention it.
Does the crackle indicate a problem with the ground wire, something with the output jack, or what? Also, I can cause the crackle on my LP Standard Faded, but I really have to TRY to do it on that one (rubbing my feet on the carpet a lot then touching the strings). On my R8, it just seems to happen any time I let go of metal and then touch the strings again.
I've tried different cables and have tried multiple amps too, and always get the problem, so I know it is the guitar. None of the wiring seems loose or touching other wires where they shouldn't be. I can't see where the ground wire is touching the bridge, so there could possibly be a problem there, but I'm not sure.
Anyone have suggestions as to what to check out? Or it this just one of those things that I have to live with?
Thanks!
Thanks!
