Why do you want such a long speaker cable? I use a 3 foot Monster and it does what it's supposed to
I need to buy a quality speaker cable for my 2061cx extension cabinet. I'm thinking a 10'-15' length. Any suggestions as to which brand and what size gauge I should go with ?
Thanks for any suggestions.
You have your answer.
Open up your cab and look at the tiny little wire that is going to the speaker.
Open up your amp, and look at the tiny little ware (or PCB-trace) that is going to the output jack. You're fine. Your cable is part of a system. An not a part that has really high requirements.
Give it no more thought than you give the A/C cable that you use to plug the amp into the wall.
Insulated? Check
Terminated? Check
Plugged in? Check
Sound coming out of speaker? Check
Done
Insulated? Check
Terminated? Check
Plugged in? Check
Done
While we are on the topic, I just made up a batch of speaker cables using a 50ft., 16AWG cable that really had no use (I hate long cables!!). I'm using the cables to run my 15W amps. As people are mentioning 12 AWG wire and lower, are these cables strong enough for my needs? They are not warm after long playing and everything sounds great. Weird analogy, but I figure I don't need a pitcher to drink a half-cup of tea.
Okay, but will a cheaper brand suck tone or color tone ? Or microphonic ?
And why 12ga, 14ga, 16 ga ?
12ga is thicker than 16ga, correct ? So maybe consider using a thicker guage for a longer run of cable ?
