jaqueh
- Joined
- Nov 11, 2020
- Messages
- 771
- Reaction score
- 533
SOLD firm. No trades or lower offers please. Shipping will be $80 max conus from California. Shipping fees are on you if any.
The neck is a perfect in between size. The flame top is very nice on these. It weighs less than 7.9 pounds. Lightest reissue I’ve come across. The VOS finish on this looks great and really hides some of the minor wear on this guitar. There is a mark near the controls and marks throughout the back that have been touched up. Nothing major but all documented. The back is super nice and dark too.
Body
Body Shape Les Paul
Body Material 1-Piece Solid Lightweight Mahogany
Top 2-Piece Figured Maple, Hide Glue Fit
Back 1-Piece Solid Lightweight Mahogany
Weight Relief None
Finish Nitrocellulose Lacquer VOS (Vintage Patina)
Neck
Material Solid Mahogany
Profile V2 Authentic '60 Slim C-Shape
Scale Length 24.75" / 628.65mm
Fingerboard Material Indian Rosewood, Hide Glue Fit
Fingerboard Radius 12"
Number Of Frets 22
Frets Authentic Medium-Jumbo
Nut Material Nylon
Nut Width 1.69" / 42.85mm
End of Board Width 2.24" / 56.89mm
Inlays Aged Cellulose Nitrate Trapezoid
Joint Long Tenon, Hide Glue Fit
Hardware
Finish Nickel
Tuner Plating Nickel
Bridge No-Wire ABR-1
Saddle Material Nickel-plated Brass
Tailpiece Lightweight Aluminum Stop Bar
Tuning Machines Kluson Single Line, Single Ring (V1) or Double Ring (V2, V3)
Pickguard Laminated Cellulose Acetate Butyrate
Truss Rod Cover Authentic Stepped 2-Ply
Control Knobs Amber Butyrate Top Hats w/ Silver Inserts
Switch Tip Amber Catalin
Switchwasher Replica Cellulose Acetate Butyrate
Jack Plate Cover Laminated Cellulose Acetate Butyrate
Control Covers Black Royalite
Strap Buttons Aluminum
Mounting Rings M69 Cellulose Acetate Butyrate
Pickup Covers Authentic Profile Nickel Silver
Electronics
Neck Pickup Custombucker Alnico III (Unpotted)
Bridge Pickup Custombucker Alnico III (Unpotted)
Controls 2 Volume/2 Tone CTS 500K Audio Taper Potentiometers, Paper-in-Oil Capacitors
Pickup Selector 3-Way Switchcraft
Output Jack Switchcraft
Miscellaneous
Strings .010, .013, .017, .026, .036, .046
Case Aged Brown/Pink Reissue 5-Latch
Accessories Certificate of Authenticity Booklet, Commemorative Switch Plate Medallion (Regular Plate in Case)
Body
Body Shape Les Paul
Weight Relief None
Neck
Number Of Frets 22
Nut Material Nylon
Hardware
Finish Nickel
Electronics
Miscellaneous
