Sold
J50315
This is a late '73 so it is the PCB version. Runs off 6550's. Very clean overall, no holes drilled in the chassis or major tolex wear. I had an issue where I was getting intermittent static so my amp tech replaced a couple caps/resistors and gave it a once over and its ready to go, just got it back tonight. A previous owner installed a master volume on the front of the amp, this has been removed. It has a mod that jumps both channels together when you are plugged into the high input of channel one and you use the volume knobs to blend the channels. This can easily be removed and put back to stock if so desired. Selling to fund a non gear related purchase so NO TRADES! Sold
bhurst462
Great amp and even better guy! Good luck on your sale brother!
Duane_the_tub
Great seller and a KILLER amp! There's gotta be someone on MLP who doesn't yet own a fire-breathing Marshall!
jenton70
You won't find a better guy to deal with and this thing is killer!
