***SOLD*** Neunaber Expanse Series Pedal and ExP Controller
Nicky
On The Road Less Traveled
For sale is a mint Neunaber Expanse Pedal with companion foot control switch. The skin on the pedal is for the Wet Stereo Reverb. However, the Expanse pedal is actually SEVEN different pedals. Using Neunaber's Expanse Software, you can download and install any one of these pedals into the box, then use the foot switch to change effects.
The pedal and controller pictured were manufactured in 2016, but have maybe an hour of use.
PRICE SHIPPED: $275
[from the website]
What is Expanse? It's a reverb, an echo, a shimmer and a chorus. It's all of these and more! Expanse can be programmed as any effect in Expanse Software:
  • Reverb (Wet, hall, plate, spring, modulated)
  • Shimmer
  • Echo, with/without reverb
  • Chorus or Detune, with/without reverb
  • Flanging
  • Phasing, Phased Doubling
  • Tremolo
Features
  • Stereo or mono input and output
  • Three controls, function depending on effect
  • Access to 4 programmable effects with 2 presets each via the ExP Controller (sold separately)
  • Mix knob goes to 100% effect
  • Selectable true bypass (no trails) or buffered bypass (with trails)
  • Selectable footswitch behavior, independent of effect (see User Guide)
  • Very high input impedance: no "tone suck"
  • Analog dry signal for low noise and zero latency
  • Small footprint
  • Requires standard 9V or 12V pedal power supply (not included)
  • Made in Orange County, California USA
Nicky
Lots of functionality.
Nicky
SEVEN pedals in ONE!
Nicky
Please note there is a small scratch on side of ExP controller. I tried to capture a macro image below.
Nicky
Tons of pedal power in this one.
