SOLD F/S Dr. Z Z-Plus 15W 6V6 combo Amp
Mike I
For sale is a one month old mint Dr. Z, Z-Plus 15 Watt amp. This amp is very harmonically rich sounding, with great cleans and outstanding overdrive. It has a half power switch that drops one 6V6 out of the circuit, and reduces power to 7 Watts. This is very useful for lower volume overdrive, as it lowers the headroom. I have only used this at home in my music room, never gigged.
It also has a really useful boost foot switch, which bypasses the tome stack for really great and articulate crunch! This foot switch also has a knob so that you can actually dial in the amount of tone stack bypass you want, and the level and tone of the crunch tone. Very useful!
This amp was designed by Dr. Z is collaboration with Joe Walsh, and it shows! Funk 49 all day on this guy!
Has multi ohm speaker outputs, effects loop, and very lush reverb.
This amp is a gigging 15 Watts, and will cut through the mix with NO problem! It can get loud!
Below is a description from the Dr. Z Website.
The Z-PLUS is a parallel, single-end amplifier in true Class A configuration, which yields a rich clean tone that smoothly overdrives into gritty, harmonic-laden distortion. Single-ended, Class A operation produces full even-order harmonics which are typically cancelled in traditional push-pull, Class A/B tube amp designs. The result is sparkling and satisfying tone with the full range of 2nd and 4th order harmonics with clarity akin to an full bodied, acoustic guitar. While typically class A designs are limited by lower clean headroom, the Z-PLUS utilizes two 6V6 power tubes in parallel which increases clean headroom, per Joe Walsh’s request.
For the best of both worlds, the inclusion of a half-power switch drops the second 6V6 out of operation, rewarding you with touch responsive drive, dynamic compression, and lowered headroom. All of the typical Dr. Z features are included: full EQ with master volume and cut, hi and lo sensitivity inputs, an effects loop, a rich reverb circuit, and our variable boost footswitch. The output transformer is a special design for this amp, constructed with the highest grade M-6 stacked laminates, coupled with our custom all-aluminum chassis, and built like a tank to UL-60065 specifications.
1400.00 plus 75.00 for shipping to the lower 48 only.
( 100.00 less than my other listings, for the MLP gang )!
