SOLD BadCat Unleash V1 Attenuator/Re-amplifier SOLD
LPnut
This unit does it all. For situations where you want to dial in the tone of your amp which requires volumes too high for the situation, it will attenuate your amp down to 1 watt so you can have that tone and not piss off the neighbors! :fingersx:
For those situations where you have a low-wattage amp (like a 5w Fender Champ or Marshall Class 5) and wish it were capable of producing more "useable" volume, it will boost your amps wattage anywhere up to 100w.
If your favorite amp does not have an fx loop, this unit does. You can insert this unit into your chain and connect the effects to it.
If you are a gigging guitarist and don't want to lug your favorite 4X12 cabinet to the gig, simply bring your favorite head and this unit; connect this unit into the FOH system and you're good to go!
SOLD shipped to CONUS and PP
[/URL][/IMG]
Here is the description from the experts at BadCat:
How Does the Unleash Differ from Load Boxes and Attenuators?
Much more than an attenuator... It's a re-amplifier!
As a working guitarist himself, company owner John Thompson knew that he was not alone in the need for a device that would allow him to play any gig at any volume through any wattage tube guitar amp. He also wanted to build something for guitarists that would enable them to rehearse, record or go direct on stage without a speaker if needed. And like most gigging guitarists, John thought it would be useful to have an external unit that added a lead boost and an effects loop to any amp... but of course he wanted all of these functions in one small lightweight enclosure. Since there was nothing even remotely close to this Swiss army knife of solutions on the market he started from scratch. Two years, four engineers and a team of beta-testing pros later God's gift to every working guitarist was born.
Here's How it Works
The Unleash converts the high voltage speaker output of any guitar amplifier up to 100 watts into a line level signal, sends it to our proprietary reactive load circuit that responds like a speaker and then into an ultra-transparent class D amplifier which allows any wattage amplifier to be adjusted between 1-100 watts without any change in dynamics or tone.
The re-amplified signal may then be sent through external speaker cabinets, the internal speaker(s) in a combo, and direct out to headphones or a recording console/ PA. Our reactive load on the input replicates the response of a loudspeaker to allow for safe silent operation when the silent switch is engaged or when no speakers are attached. The line out offers convincing speaker simulation into a PA, recording console or headphones.
The Unleash also adds the following features to any guitar amp: two foot-switchable channels for rhythm and lead levels, dual speaker outputs to mix and match 4, 8 or 16 ohm speaker cabinets and a post-power-tube effects loop for pristine reverb, delays and modulation.
Features
• Two foot-switchable channels
• Effects Loop
• Reactive Load Input (patent pending). Pushes back like a real speaker so tube amps behave naturally and don't experience the strain of common load boxes and attenuators.
• Adjustable input impedance for 4, 8, 16 ohm guitar amplifiers
• Two speaker outputs with variable impedance to pair 4, 8, or 16 ohm loads
• Speaker phase switch
• Silent operation switch
• Error-proof circuit protection to guard against improper cable connection
• 1 to 100 watt output
Recommended Applications
• Re-amplify a low wattage amp into a 1-100 watt amp
• Attenuate a high wattage amp into a 1-100 watt amp
• Dial in the sweet spot on your tube amp at any volume while retaining tone and feel
• Run the master volume on your guitar amp wide open to maximize power tube harmonics
• Add foot-switchable rhythm & lead master levels to your amp
• Add an effects loop to your amp
• Turn a combo into a wet-dry rig by running 100% wet effects to an extension cab
• Safely use any tube amp at any gain level without a speaker
• Gig, record, or practice silently using the line out with speaker simulation
• Use the line out to a console in conjunction with your amplifier speaker adjusted to stage monitor level
• Cover a gig with just a head direct into the PA and sound like your playing through a mic'ed up cab
