Single coil wiring issue?
Oldhand
I've been modding an Epi Strat S series as an experiment and have run into what I think is a wiring issue. All pups are single coil. I installed an SD Twangbanger bridge, SD Alnico 2 Pro RWRP middle, and a Fender Fat 50s neck, standard wired 5 way pup switch. All switch positions sound great except #2 (neck + middle) that sounds weak and thin. Do I need to reverse the Fender pup wires? I think it may be out of phase with the middle. Any ideas are welcome.
Oldhand
Freeform
Thanks, I thought I remembered a Fender issue with mixing pups. Rewired accordingly and the problem is fixed! MLP members are great!
